Fuel pressure observation
Old Mar 7, 2013 | 03:16 PM
james2562's Avatar
Default Fuel pressure observation
I splicedin a pressure gauge just before the IP. I drove a couple of days and the pressure appears to be consistant. In the morning when everything is cold; When I turn the ignition to on and the LP starts up the fuel pressure reads 8psi plus or minus a pound. When I fire up the engine pressure drops down to 6psi plus or minus a pound. Later in the afternoon when it is warmer out 50s or 60s pressure drops to 3.5psi plus or minus a pound. When I am accelerating to freeway speeds the pressure drops down to almost 0psi.
Is this normal? what kind of pressures are yall seeing.
I am thinking that as things heated up the fuel thinned and the hose expanded resulting in the drop of pressure.
Old Mar 7, 2013 | 04:30 PM
MillerBoyzDiesel's Avatar
you want it to be around 5 even at wot
Old Mar 7, 2013 | 06:06 PM
Mayhem's Avatar
Try running with the fuel cap loose our caps need to breath if that dont make a difference you may be looking at a new LP or OPS.
Old Mar 7, 2013 | 08:03 PM
james2562's Avatar
Default great idea. When I open the tank to fill up there is a serious vacume.
If their is vacume in my tank is their a gas cap I could use that will allow the tank to breath?
Old Mar 7, 2013 | 08:27 PM
Mayhem's Avatar
If you have vachuum in the tank you have a problem get a new diesel cap
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
