Still getting that funny throttle...
Old Mar 6, 2013 | 09:08 AM
SRTcummins's Avatar
Default Still getting that funny throttle...
Ill be driving down the road when its cold and ill start to get that throttle I described earlier (it would be really easy to pussh to a point then it would hit like a wall, and when you went passed the "wall" the throttle would return to normal tension.)
Theres nothing wrong with the IP, it still gives me fuel when the throttle gets all funny, the only problem is shifting, it will get stuck at what ever gear it happens in. When this happens i floor it and the throttle returns to normal tension and shifts perfectly fine.
Fuel pressure: 14 at idle Hasnt seen lower then 12 at WOT or anything else.
adjusted bands 3 weeks ago now. What do you guys suspect?
it seems to do it mainly when its cold but i cant think of any other symptoms
Old Mar 6, 2013 | 09:21 AM
Mopar1973Man's Avatar
Sounds like a transmission issue on the kick down linkage.
Old Mar 6, 2013 | 10:05 AM
SRTcummins's Avatar
Do either you or somebody sell a kick down replacement? how do i go about checking this??
and thanks for the input!
Old Mar 6, 2013 | 10:21 AM
MillerBoyzDiesel's Avatar
its a throttle valve cable that measures throttle angle to adjust shift timing and pressure sounds like yours is binding up either on the bracket on the trans or against the body somewhere
Old Mar 6, 2013 | 01:17 PM
SRTcummins's Avatar
but what causes the throttle to get all soft but i still have the same fueling as normal throttle tension. It is just very soft like nothing under my foot but when i press it, it defilently is still there
Ill check the cable, maybe my buddy hit it or something when we were doing the bands
Colbyflory
Aug 16, 2021 09:19 AM
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
1stgenswap
Nov 3, 2014 09:45 PM
