What coolant temp is normal?
Old Mar 6, 2013 | 09:04 AM
Fourdoor's Avatar
Default What coolant temp is normal?
I hooked up the livewire TS the other day, and set up some gauges including coolant temp and oil temp. My coolant temperature maxed out at 174 to 176 (cruising on highway at 70 mph) and my oil temp was 192 to 194. This is almost a 20F spread, but the coolant temp seemed low, so I wasn't sure if it was reading correctly. I already have a new oil cooler to put in, just wondering if I need a new thermostate or a new coolant temperature sensor, or if those coolant temps are normal.
Thanks,
Keith
Old Mar 7, 2013 | 12:24 PM
MillerBoyzDiesel's Avatar
coolant temp is ok, oil temp needs to be addressed
Old Mar 7, 2013 | 02:58 PM
bobfbigman's Avatar
The coolant temp should be right around 190, it helps with power and fuel mileage, the spread is too much so it is good you have a new oil cooler ready to go in, add a coolant filter so you don't have a clogged cooler again. I believe you need a new thermostat, these trucks get best mileage when run right at 190deg.
Old Mar 7, 2013 | 04:08 PM
Fourdoor's Avatar
Yup, have the oil cooler and coolant filter sitting in the shop ready to be installed, along with my 4" catless exhaust, new fuel filters, and EGR delete Just needed to know if I needed a thermostate as well. Thanks I assume I can get the correct T-state from my local Ford dealership.
Later,
Keith
Old Mar 7, 2013 | 08:40 PM
bobfbigman's Avatar
Yup, most part places will have them too, probably alot cheaper, it i the whole housing with the hose connection as part of it.
Old Apr 1, 2013 | 03:16 PM
bustedknuckles's Avatar
Seems like a bad coolant temp sensor could save you a lot of un-needed work.
Not saying that's the problem, however, a coolant temp sensor that reads 20 degrees low could explain a lot (the 2nd clue is oil temp = 190, which is right in there where it should be).
caissiel
Sep 24, 2015 05:37 PM
Bull Grunt
May 15, 2015 09:55 AM
Bull Grunt
May 3, 2015 06:38 AM
emilio2496
8
Jan 13, 2015 05:03 PM
97f-250
Nov 23, 2014 08:08 PM
