Problems
Old Mar 5, 2013 | 03:03 PM
DodgeJohn2013's Avatar
Default Problems
I have lots of problems going on with my 2001 2500. Im thinking that my engine breather is plugged. Would that cause my turbo to start leaking oil because of the pressure build-up? Do you even need the bottle that your breather tube goes into?
Old Mar 5, 2013 | 03:57 PM
shellinger's Avatar
no you dont need the bottle. mine goes onto the ground
Old Mar 5, 2013 | 04:16 PM
i checked the bottle and the hose and everything was clean. Im trying to figure out why my turbo is leaking oil. It has very little play. Any suggestions?
Old Mar 5, 2013 | 07:43 PM
Mopar1973Man's Avatar
Here is my modified breather tube...
Mopar1973Man's Dodge Cummins Articles - Crankcase Vent Modification
As for your turbo here is how to properly check it.
Mopar1973Man's Dodge Cummins Articles - Turbo inspection
Typically if the shaft move in or out like a old school headlight **** there is problems. If there is any oil leakage typically that a bad sign of seals and/or bearing issues.
Bloom12valve
Oct 9, 2015 03:40 PM
J. Nick
Apr 24, 2015 01:13 PM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
JRB1960
Dec 1, 2014 09:24 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
