Vin # 6 or 7
Old Mar 4, 2013 | 08:51 PM
DevonMolendyk's Avatar
Default Vin # 6 or 7
When im looking for certain parts im asked if my truck is vin code 6 or 7. what is the difference and what number in the vin is it?
Old Mar 4, 2013 | 10:13 PM
toughtoy4x4's Avatar
I believe it's the 8th digit in the VIN and the "6" indicates the engine is the standard output (235HP) version and "7" is for the high output (245HP) version of the Cummins 24V ISB. Hope this helps!
Old Mar 5, 2013 | 12:27 AM
Ramitt's Avatar
^^ Yep. I have the h.o and my vin number is 7
Old Mar 7, 2013 | 01:04 PM
jkidd's Avatar
the vin7 HO or ETH is a 6spd with a 245HP rated engine. the injectors are actually smaller than what is in the vin6 and swapping will add about 10hp. The 028 vp44 that is in the vin7 is a stroked pump that has advanced timing and more aggressive fueling down low. The 027 pump will flow more fuel and will gain about 20hp more from a programmer/box as it does not have as much timing built in to the programming. combining the stroked 028 head and cam with the larger plungers of the 027 = hotrod vp44.
Old Mar 9, 2013 | 04:55 AM
AlaskanRenegade's Avatar
^^ just made me sad..
I've never really looked into the 6/7 thing, but I was told that since mine has a HX35 on an auto, she was a HO. Oh well. She's got more power than a stock HO so it's ok
Might look into the whole hotrod vp44 mods in the future.
Old Mar 9, 2013 | 08:10 AM
mysterync's Avatar
The SO is capable of more power than the ho in the first place?!
Old Mar 9, 2013 | 09:39 AM
Mopar1973Man's Avatar
Yea... That's why the HR pumps are build with the SO parts for most of it. But use a few HO part to give that added bump. This why most would just suggest getting a SO pump and not bother because now a module will enhance a SO better than a HO.
Old Mar 9, 2013 | 10:20 AM
mysterync's Avatar
The hot rod pumps are junk. I made less power with a hot rod than a SO. By less i mean over 200 less
Old Mar 9, 2013 | 11:05 AM
Whoa! Now that a serious number claim...
Old Mar 9, 2013 | 04:31 PM
mysterync's Avatar
It just couldn't fuel like the so. Ran out of fuel under 540 on fuel only and 630 on the bottle. The only thing that had changed was the dyno but you could tell it lacked the fuel.
Exact same setup with SO vp made 597 on fuel and 839 on spray. The hrvp was installed and ran after i sold the truck.
