6.9 oil cooler questions
Old Mar 4, 2013 | 08:51 PM
strokedout6.9turbo's Avatar
Default 6.9 oil cooler questions
in the process of buying an 85 rclb 4x4 with 6.9 t-18 and 3.54 gears only paying 1400 bucks for it and the body is a solid 9/10 the problem is that oil is leaking into the coolant and i remember they guy sayig that either him or his friend (the previous owner before him) re o-ringed the oil cooler if the problem is the o-rings then its no issue to just o-ring it and go on but if it is say the core itself can i block off the oil cooler and run an external cooler up front using one of the plates that screws onto the oil filter threads
just realized that the oil filter screws on to the rear piece of the oil cooler but i could make two plates the have welded on fittings for both coolant and oil and have the oil run through a remote filter and then through this heat exchanger all for about 200 dollars less than the replacement core 26.4 GPM Return Line Heat Exchanger | Princess Auto
Last edited by strokedout6.9turbo; Mar 4, 2013 at 08:51 PM. Reason: Automerged Doublepost
Old Mar 11, 2013 | 03:43 PM
bump
Old Mar 29, 2013 | 01:38 AM
dieselgirl86's Avatar
It could possible that the o-ring move when they put it on so that is a possibility
Old Apr 11, 2013 | 10:56 AM
chrislowe95's Avatar
i had to do the same thing, core had pinholes all over it, from rust of course. got a new core from mr. cool for about $200, and the gasket and oring kit for around $20. put the orings on pressed the end caps on, bolted it on, and good as new.
Old Apr 11, 2013 | 11:54 AM
Slim Whitey's Avatar
just buy a new core for next to **** all.
Edit:
I dunno how you are running that cost to get a core for it. that's nuts.
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
tim12valve
May 6, 2015 10:40 PM
Bighouse
Apr 9, 2015 06:51 PM
emilio2496
8
Jan 13, 2015 05:03 PM
bypass-21
Dec 15, 2014 08:52 AM
