Borgeson steering shaft
Old Mar 4, 2013 | 03:46 PM
CUMMINStagetcha19's Avatar
Default Borgeson steering shaft
Wondering how other first genners like the borgeson steering shafts. And also how the borgeson steering boxes hold up. My rag joint and shoe and bucket steering shaft has had it. Wondering if its worth the money.
Old Mar 4, 2013 | 08:05 PM
olsmokey's Avatar
the borgeson shaft i put on my 93 was one of the best things i put on the truck (besides go fast parts) they are a little costly but what an upgrade.
Old Mar 4, 2013 | 09:35 PM
geddy's uncle's Avatar
Both Tiny and Da Beast have Borgeson shafts. They made the difference between herding and steering . Been fortunate, and haven't had to do boxes, braces, etc. etc., so don't know about those parts.
Old Mar 17, 2013 | 11:02 AM
Rlbuben's Avatar
I put a borgeson shaft on my 93, as I had a lot of slop in steering, took most of it away,tie rod ends fixed the rest. I would sand and repaint though, mine started to rust after a few mounths.
Old Mar 17, 2013 | 03:33 PM
With all of this input, I would need the 30 spline double u joint with needle bearings, right? I have a 92 and as far as I can tell I have a splined steering wheel side. What trucks had splined upper shafts as opposed to non splined upper shafts? And do they have a slip joint so I don't have to remove the steering box again.... I just did that today.
Old Mar 18, 2013 | 07:36 PM
Rlbuben's Avatar
The borgeson steering shaft I put on my 93 had splined on both ends with a slip joint near center.
Old Mar 19, 2013 | 08:41 PM
Coolfacker's Avatar
I rebuilt the stock shaft and in a month threw on the Borgeson and don'te regret it one bit. Made a helluva difference, especially driving with a cross wind!
Old Mar 20, 2013 | 06:25 PM
What I meant was, is the upper shaft, the rag joint side, splined on all trucks? Way it sounded on boregsons site some have splines some don't. I believe mine does.... That being said just wanted input so I don't get the wrong shaft and have to go through more work!
Antwhite19
Aug 23, 2015 06:07 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Beelzeboss
Feb 28, 2015 07:30 AM
sweetv8s10
Oct 7, 2014 09:47 PM
