Loses fuel pressure
Old Mar 4, 2013 | 02:21 PM
ACSchex's Avatar
Default Loses fuel pressure
I have a 2006 Dodge 2500 5.9. This truck cranks up and runs at correct fuel pressure and then slowly loses it and dies out. It does not lose prime as it always fires right back up. We have tried changing the high pressure pump, lift pump in the fuel tank, crank shaft position sensor, cleaned fuel filter housing assembly... we are stumped at the next step to turn. Any help will be greatly appreciated!!
Old Mar 4, 2013 | 02:38 PM
MillerBoyzDiesel's Avatar
loses supply pressure or rail pressure? If you are meaning rail pressure, check torque on the fuel inlet tube nuts.
Old Mar 4, 2013 | 02:49 PM
ACSchex's Avatar
It has a trouble code of PO148
Where would that be located?
Old Mar 4, 2013 | 03:46 PM
yeah thats fuel rail press. code, the nuts that hold the fuel inlet tubes in are on the side of the cylinder head they screw into the head theres one on for each injector. look where your injector lines run to from the rail and youll see the 24mm nuts that are screwed into the head tighten those up
Old Mar 5, 2013 | 09:51 AM
ACSchex's Avatar
We are experiencing a loss of power after about 5 miles of driving and then dies out before it gets to base idle
Old Mar 5, 2013 | 09:54 AM
did you check the nuts? sounds all too familiar
Old Mar 5, 2013 | 01:03 PM
Bigg Redd's Avatar
Good info here. I too have an 06, but I dont have that issue......Yet! Keep the info coming.
Old Mar 5, 2013 | 02:31 PM
ACSchex's Avatar
We are checking that right now, I will let you know the outcome, thank you so much for the help!!
Old Mar 5, 2013 | 06:19 PM
dcpowell17's Avatar
Sounds like a fuel pressure regulator to me.
Old Mar 6, 2013 | 08:57 AM
ACSchex's Avatar
Thank you MillerBoyzDiesel, this fixed our issue!!
