need a clutch
Old Mar 4, 2013 | 09:59 AM
scottmorgan's Avatar
Default need a clutch
i have a 2001.5 with the ho 6sp tranny
i have 100 hp injectors
i have quadzillla adrenaline
its my daily driver
im intrested in nmu70279-04 with a 3850 pressure plate but im open to all
i want to keep cost down.
Old Mar 4, 2013 | 11:53 AM
H.R.D's Avatar
Is that a single or dual disk clutch? A single disk rated for around 400+ hp is going to have a rough engagement. I would recommend a street dual disk for smooth engagement and great holding power.
Old Mar 4, 2013 | 06:33 PM
shellinger's Avatar
if you are just towing with it or hot rodding around once in a while the dual disc south bend 3250 would suit you best. if you are going to any sled pulling, tug of war or drag racing i would get the south bend dual disc 3600, or 3850 sfi rated. the 3250dd with the organic combo discs does not slip well.
Old Mar 5, 2013 | 12:31 AM
Ramitt's Avatar
I run the southbend dd 3600 and it is semi grippy but you get used to it after awhile. The 3250 dd would be a good setup!
Old Mar 5, 2013 | 05:12 AM
i'm probley going to run a valair just because the clutch i had was a valair and they will work with me on prices. looking at them witch clutch should i get?
Old Mar 5, 2013 | 07:57 PM
Mopar1973Man's Avatar
I'm running a Southbend Con OFE clutch. Wonderful single disc clutch with excellent manners. Holds up to the HP/TQ I'm producing to the point that even hitch up to my RV I can still break the tires loose in 2nd gear and bark 3rd in not careful. Seriously she sticks good!
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
lmshowalter
5.9L 24V Performance
Jul 16, 2015 06:39 PM
Dozey
Mar 5, 2015 01:49 PM
Wyocumins
Oct 19, 2014 09:34 PM
