Start-Quit-Run
Old Mar 27, 2008 | 09:50 AM
cummincrazy's Avatar
Default Start-Quit-Run
My truck will start then drop down to 2 psi quit I wait a min try agaun and it starts runs fine
changed filter checked to see if i was getting power to pump after it started. I just put in new ATS tranny I do not see tht could be it but you guys need to know it all. You always help.Thanks
Old Mar 27, 2008 | 10:01 AM
Whit's Avatar
Site Mascot
resett yer APPS and see if that helps
I know it sounds wrong but this has worked for alot of peeps in the past
Old Mar 27, 2008 | 10:06 AM
Default thanks
Worth a try How do i reset the apps? I Guess i could look it up. I think i am lazy
Old Mar 27, 2008 | 12:58 PM
Whit's Avatar
Site Mascot
turn key on
slowly press throttle all the way to floor
slowly release pedle all the way off
turn key off
restart
it is now reprogramed
Old Mar 29, 2008 | 10:49 PM
I tried that it did not work so i changed the pump. Now when i bump the starter it only goes to5psi then drops to 1 psi. Any suggestions I only had 16000 0n the last pump
Old Mar 29, 2008 | 10:55 PM
Uncle Bubba's Avatar
Put a meter on the line to see if your getting a voltage drop to go along with that pressure drop. It should hold the stead 12V all the time it's running. If your current stays good then I would guess the LP is going bad.
Old Mar 29, 2008 | 11:26 PM
Default start run
WE did that at the shop it held fine
Old Mar 30, 2008 | 12:23 PM
If it's holding current then you can either drop the tank to make sure the pick up tube isn't clogged with gunk from the tank, or you can pull the incoming fuel line off the filter and run it into a bucket to do a flow test on the LP. Either way if your holding voltage to the pump and losing psi you will be replacing the LP anyway. The pump is either getting weak or the internal overflow is worn out and hanging open.
Wher is you pressure guage tapped into the fuel line at.
vin_diesel
Mar 1, 2016 01:43 PM
moparisthebest
23
Oct 15, 2015 12:13 PM
Cavnar
Sep 9, 2015 07:18 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
