nv4500 shaft play?
Old Mar 3, 2013 | 05:28 PM
dieseldude848's Avatar
Default nv4500 shaft play?
hey, just wondering if there should be any shaft play between the input and tail shaft? i have about a 1/4'' of play left to right.
Old Mar 3, 2013 | 05:35 PM
Mopar1973Man's Avatar
I would have to say there is bearing issues.
Old Mar 4, 2013 | 06:32 AM
So I'm guessing there should be zero play? And could it be just the bearing on the input shaft? I don't want too rip it completely apart.
Old Mar 4, 2013 | 07:55 AM
Thing about it... The input shaft rides in the pilot bearing and on the input shaft bearing. Then its got a sliding clutch plate on the splines. Now assume the clutch material is not exactly perfect in balance. So what do you thing will happen when you rev that engine up press the clutch pedal on have the free spinning mass? It going to jump all around on that input bearing as well as trying to tweak the pilot bearing. I would suggest in replacement.
Old Mar 4, 2013 | 11:43 AM
It's doesn't have any shaft play like a turbo would have. I'm talking about the rotational movement/play it has meeting up with the trail shaft and other gears inside. There's no more then a 1/4" of it back and forth. If I hold the tail shaft and rotate the input back and forth.
Old Mar 5, 2013 | 01:43 PM
RollinCoal99's Avatar
have a professional look at it
Oct 2, 2015 12:00 PM
klu408
Price Quote - Request A Price
Apr 26, 2015 07:28 PM
Robert hawkins
Feb 23, 2015 08:06 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
GreenDieselF
Nov 9, 2014 07:18 PM
