4x4 Broke
Old Mar 27, 2008 | 01:34 AM
94cummins12v's Avatar
Default 4x4 Broke
just got don muddin and broke the 4x4, think the front ring and pinion are gone but not sure yet goes into 4X4 and drive shaft spins but no power to tires, great fun but something broke o well
Old Mar 27, 2008 | 01:44 AM
2500HeavyDuty's Avatar
Clean er up and take a good look in the morning, usually stuff hides under all that mud
Old Mar 27, 2008 | 01:51 AM
i already know its something internal cause when i turn it makes a loud clunk and the the shaft turns but tires dont
Old Mar 27, 2008 | 01:53 AM
does your rack and pinion move?
Old Mar 27, 2008 | 01:54 AM
it turns if thats what your asking it just makes a clunk
Old Mar 27, 2008 | 02:04 AM
LOGANSTANFORTH's Avatar
is your Center Axle Disconnect working????, if it is, sounds like spider gears, if you was in 4x4 and your front ring and pinion locked up you would of ate dash board....
Old Mar 27, 2008 | 02:06 AM
Old Mar 27, 2008 | 02:36 AM
nooblet's Avatar
I'm guessing spider gears also. Its not easy to break a D60 R&P, and if you did I doubt your front D-shaft would even turn. Could be your CAD too. Pop the diff cover and I'm sure you'll know real fast!
Old Mar 27, 2008 | 07:48 PM
ok i found out what the clunck was when i turn the stering slabalizer was loose the reason the 4x4 dont work is i snaped the driver side axle shaft. i know this becasue with the diff cover off an turn the drive shaft the short axle shaft wont turn cause its one with the u-joint now it turns which means it aint conected
Old Mar 27, 2008 | 08:27 PM
you want to explain those last 2 lines a little better please.....
