Call me crazy.... 24v head?
Old Mar 2, 2013 | 03:14 PM
CUMMINStagetcha19's Avatar
Default Call me crazy.... 24v head?
Just a thought, But how would a 24v head work on a first gen truck. In the thoughts of performance, the four valves per cylinder flow much better than the 2 counterpart. Only thing I'm not sure of is how lines would work and if the increased flow would benefit us and the VE could keep it fueled etc and what it would do to egts.
Old Mar 2, 2013 | 03:20 PM
Red_Rattler's Avatar
High Tech Redneck
Wrong piston design for the 24v injectors so you'd need to change them, custom injectors, custom lines and a few other things. What your trying to gain is not worth the effort unless this is an all out high hp build and even then a 12v with machining and runner intake can and will be more than adequate. I'd rather spend money elsewhere if I was you.
Old Mar 2, 2013 | 03:23 PM
High Tech Redneck
Oh and to flowing better than 2 valves. Not by as much as you think it would also I have a highly worked over 12v head on my puller that will flat out flow any 24v or is comparable to a full out 24v one.
Old Mar 3, 2013 | 11:19 AM
What I was getting at. I didn't know what all would need to change. Would be cool to say I did it!
Old Mar 4, 2013 | 09:42 PM
GrudgeGuy's Avatar
would you be money ahead to just get a 24v motor and put the mechanical VE setup on it? I've seen them with P's so I assume it can be done. I've thought about this too
Old Mar 4, 2013 | 09:48 PM
geddy's uncle's Avatar
valve-train drive conversion would also be .... involved.... I presume. You want to have too many valves, get one that was already made with too many valves, and don't use a VE . Go to a P . Or do like that other guy and port your existing properly-numbered-heads really well.
Old Mar 5, 2013 | 02:34 PM
cummins_guy's Avatar
im working on injector sleeves, so that you can just drop the 12valve injectors in and use the fuel lines, all you would need to do is just change pistons.
should have something by late spring.
gd1996
For Sale
May 15, 2015 09:42 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
