hard starting
Old Mar 2, 2013 | 10:41 AM
theartporter's Avatar
Default hard starting
1997 ford f 250 hd diesel, 150000 miles, hot or cold, turns over good , glow start light works, unusually long cranking...sputter start, white grey smoke. New filter... fuel pump(top back center motor replaced 100000 mi) ???
Old Mar 2, 2013 | 01:14 PM
POWER-STRUCK's Avatar
does it consume oil? could have bad injector orings
Old Mar 2, 2013 | 02:32 PM
thanks...yes it seems to consume approx 1 qt per tank(20g) how to fix?
Old Mar 2, 2013 | 02:51 PM
get 8 motorcraft cm5010 oring kits, pull the injectors and glow plugs, replace the orings, clean the injector cups, install the injectors to the proper torque, set the valve covers back on and crank the engine with the glow plugs out to evacuate the oil from the cylinders, test the glow plugs and install new ones if needed, fill hpop reservoir, crank the engine a bit then refill again, then crank til it starts, after it starts let it run a while and observe the injectors returning oil properly, retorque the injectors, reassemble and enjoy!
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
