1991 6.2l coolant leak
Old Mar 2, 2013 | 10:23 AM
scrappiron68's Avatar
Default 1991 6.2l coolant leak
i just put new head gaskets on this '91 chevy 6.2l and now its leaking coolant from the back driver side of the block. where could the coolant be coming from.
Old Mar 2, 2013 | 04:52 PM
racer55's Avatar
The rear of the heads have coolant passage coverplates-could be leaking from one of them or their studs?
Glow relay is often mounted to a rear stud in that area and would have needed some pipe sealer when re-installed.
Old Mar 3, 2013 | 09:43 PM
MontanaTechPetroleum's Avatar
My 6.5 leaked from the block heater, caused by it shorting out. When I put a lower hose heater on it, I used some of that Bars stop leak powder and it doesn't leak antifreeze now, motor oil and power steering completely different story however. Might try it, its 1.62 at walmart, but you need about 3-4 bars of it, but it worked pretty good. If its a big leak, might not try it.
Old Mar 6, 2013 | 10:58 PM
guy who worked on it after i left didn't tighten the cover plates. all good
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
