Installed DIY cold air intake won't stay running
Old Mar 1, 2013 | 10:21 PM
Petey3's Avatar
Default Installed DIY cold air intake won't stay running
Okay so I have a ts 6 position chip so I figured I should have a lil more air flow and after installing my 6637 filter when I have my chip set on stalk it runs for 10 seconds then dies but if I have it set on +50 on up to +140 it runs and idles fine. Any ideas? Until then il keep it out of stalk
Old Mar 1, 2013 | 10:37 PM
POWER-STRUCK's Avatar
bad switch? improperly programmed chip?
Old Mar 1, 2013 | 10:45 PM
Petey3's Avatar
No because it worked just fine before I put the new air filter would putting the MAFS back in the filter change anything?
Old Mar 1, 2013 | 11:05 PM
what maf?
Old Mar 1, 2013 | 11:08 PM
Petey3's Avatar
Mass air flow sensor
Old Mar 2, 2013 | 03:09 PM
no MAF present on a 7.3
Old Mar 2, 2013 | 03:37 PM
Red_Rattler's Avatar
High Tech Redneck
What ever you unhooked and removed with the stock intake has to be put back into the new one.
Old Mar 6, 2013 | 10:11 PM
BVFD54's Avatar
IDI does not use chips or maf..... these engines are mechanical and do not have a engine computer
shawnecarter
6.0L Performance
Mar 17, 2015 05:49 AM
hoeky22
Jan 2, 2015 04:54 PM
Project_5.9diesel
Dec 11, 2014 09:41 PM
12vbomber
Nov 4, 2014 10:04 PM
petew
Oct 25, 2014 09:29 PM
