Recharging My A/C Unit
Old Mar 26, 2008 | 06:30 PM
Whit's Avatar
Site Mascot
Default Recharging My A/C Unit
Well warmer months are on their way and soon I will be wanting some AC
a few months ago I did me a new VP44 and I opted to pull the whole front end off so I could snoop around for some other things..........anyway I had to depressure my AC and pull the condensor
So someone tune me up as to what I hafta do to get my AC back........
do I need to pull a vacumn on it the load the new juice or what??
Also whats the new refrigerent stuff called ??
Old Mar 26, 2008 | 07:19 PM
sawmillman's Avatar
well I did a/c work on a 94 chevy couple years ago you will have to pull a vac on the system check the oil very important use R134a refrigent.I would replace the orface tube its a filter for the system.
Old Mar 26, 2008 | 07:24 PM
Benjamin's Avatar
Bombardier
replace your orfice tube, on your truck it is fixed so you have to replace a piece of pipe..... MT0829 from Autozone and it's $16.99 ......you can also flush your system if need be if you think it has been contaminated. the flush is like $15 at autozone and comes in an aerosol can...... it wouldn't hurt to pull a vaccum on it since you pulled it appart and could have damaged the o-rings. you can always replace all the o-rings in the system, MT2507 from Autozone again and it's $6.99 <---this is the whole kit for your truck. every o-ring and seal in the tubing system. don't forget to get the correct weight oil your truck uses SP-20 PAG oil. the truck holds a total of 7.1 oz of oil but you should only need to add 3-4 oz since there is still oil in there. you can add it directly to the tubes when they are open while you are replacing the orings. your system takes 0.907 Kg (32 oz.) of R134a refrigerant. it's best to have the correct gauge setup so you can read the high and low pressure sides to make sure there aren't any blockages anywhere. other than that you should be good to go.be sure to crank the truck and turn the a/c on max and wide open on the fan before you start charging. the pressure switch will cycle the compressor on and off while it charges until it gets full. if you want to change the compressor switch for s&g's it is MT1007 from Autozone for $37.99........
Edit : don't forget to charge the system on the low side (the port with the blue cap over it) as on the high side won't yeild good results or safe ones for that matter.....
hope this helps
Disclamer - I am not a mechanic, I aint ASE certified, but have helped and watched a mechanic do hundreds of a/c systems. I even hit the charge button a few times..... oh and I stayed in a Holiday Inn Express last night
Old Mar 26, 2008 | 07:35 PM
DangerousDuramax's Avatar
Old Mar 26, 2008 | 09:49 PM
Whit's Avatar
Site Mascot
Damn Benj......................excellent info thanks stud
Old Mar 27, 2008 | 01:12 AM
01quadcab's Avatar
the fitting will not fit the high pressure line if you use the recharge cans you get at any local parts store with the line and guage on them. It comes preloaded with oil etc just read the can and put it in it's easy. I converted my old toy to the new stuff with just a kit and didn't flush the system or change anything and it worked fine and it was empty for years. just added new lines cuz they had holes in them
Old Mar 27, 2008 | 01:40 PM
94Matt's Avatar
I am now setup for auto A/C, after years of trying to tell family members that I only work on real A/C's I finally gave in and got the fittings last summer. Bring it up this way and I can set you up.
Old Mar 27, 2008 | 01:47 PM
LOGANSTANFORTH's Avatar
A/C systems are a piece of cake to work on, i should know, i got a 95% in A/C class in college
Old Mar 27, 2008 | 02:34 PM
Whit's Avatar
Site Mascot
Excellent............ sat and sunday works for me bud...............when ya want it
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Maclain Marsh
Jul 13, 2015 06:23 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
dawnrogerl
Air Dog
Jan 23, 2015 03:09 PM
