Just Making sure.
Old Feb 27, 2013 | 09:06 AM
Fastlane17's Avatar
Default Just Making sure.
have a 02, auto. intake. exhuast.airdog. at running temp its at 190. cruising, my fuel pressure is 14-15. boost at WOT is 18. (hx35 swapped) my egts sit at about 800. how does everything sound? also, how often should i change my filters on the airdog? and what are the filter size?
Old Feb 27, 2013 | 09:49 AM
Mopar1973Man's Avatar
Sound like you need to add a boost elbow and a bit more fuel.
When the fuel pressure drops. Like I've got a bit over 30K on my AirDog 150 filter and barely lost about 1-2 PSI. Not enough to worry yet because my WOT pressure is still 16 PSI I'm not even worried.
I'm running 2-3 micron filters for the best protection of the VP44. (Fleetgaurd or Donaldson)
Mopar1973Man's Dodge Cummins Articles - AirDog Filter Numbers
Old Feb 27, 2013 | 10:09 AM
Fastlane17's Avatar
Boost elbow? I'm getting a quadzilla Friday. It's free. So dont hate yet!
FF100-5 (5 Micron) Fleetguard FF5587
Part number? For the filters for the water fuel separator?
Last edited by Fastlane17; Feb 27, 2013 at 10:09 AM. Reason: Automerged Doublepost
Old Feb 27, 2013 | 10:53 AM
Remember Quadzilla is out of business and there is no support for it.
Hit the link on my last post its got all the AirDog filter numbers.
Old Feb 27, 2013 | 11:12 AM
Fastlane17's Avatar
It was either quadzilla or banks. I'm trading for a EZ off a common rail.
Alright. I have aftermarket filters currently. So I guess just go get those same filters?
Old Feb 27, 2013 | 11:28 AM
Just check on the micron rating of the filter before buying them. Brand name isn't as important as the micron rating. I tend to so far like Fleetguard or Donaldson filters...
Old Feb 27, 2013 | 02:23 PM
Fastlane17's Avatar
Alright. I just wanna make sure it will fit.
EGT is around 6-7. Not 8.
Last edited by Fastlane17; Feb 27, 2013 at 02:23 PM. Reason: Automerged Doublepost
Old Feb 27, 2013 | 10:23 PM
condor74's Avatar
It is good to see that I am not the only one that preaches the use of these filters on Diesels. I also like Baldwin filters. Mopar filters for Cummins diesel are manufactured by Fleetguard so you wont go wrong with those either.
Old Feb 27, 2013 | 10:39 PM
Fastlane17's Avatar
Still not sure which filter I need. Can someone just post what I need. Exactly. L
Old Feb 27, 2013 | 10:49 PM
condor74's Avatar
If the fuel filter set up is manufactured by Air Dog then I would check with them on what size and style of filter they use. Unfortunately I do not have an Air Dog filter set up. Most of my experience is with mostly stock trucks. I recommend changing the fuel filter on a stock truck every 10 to 15000 miles.
