VE rebuild
Old Feb 25, 2013 | 07:00 AM
01freeman's Avatar
Default VE rebuild
Does anyone know if a good shop to get a VE rebuilt at. i have a 90 that I purchased and the previous owner hooked up a high pressure pump and blew the seals out of the inj. pump. Or is there a kit an is it hard to do your self.
Thanks
Old Feb 25, 2013 | 03:29 PM
bladeyamaha's Avatar
If its just the AFC gasket, etc. its easy to replace gaskets, if it needs a complete rebuild, much more complicated.
Old Feb 25, 2013 | 04:57 PM
BC847's Avatar
Excessive inlet fuel pressure can blow the main input-shaft seal. Happens often. No big whoop. (Once the new seal is installed, some extra protection can be had by applying some GREEN thread-locker. See red arrow).
The AFC has no gaskets. There is however, a small O-ring that seals the needle that rides the cone (what we call the fuel-pin). It leaks more often due to one using a fuel-pin that's cut too deep allowing the needle to over-extend, and get past the O-ring.
Old Feb 25, 2013 | 07:41 PM
The AFC cover has no gaskets, uh WTF?
I'd hate to have trying to follow your instructions on how to change out the Gov. Spring then.
Last edited by bladeyamaha; Feb 25, 2013 at 07:41 PM. Reason: Automerged Doublepost
Old Feb 25, 2013 | 07:57 PM
BC847's Avatar
The only penetration into the AFC that could pass fuel is for the Guide-Pin (part #4). The Guide-Pin is sealed with an O-ring.
I can write a decent "How-To" I reckon.
Old Mar 4, 2013 | 02:46 AM
36Valved I6s's Avatar
I could use a decent write up on how to do the rebuild.....add in a 14mm head and that 4mm cam plate....thatd be great!
Old Mar 4, 2013 | 05:23 PM
BC847's Avatar
It's my understanding that to date, no one has been able to make that combination work, and last more than some minutes.
Someone correct me if I'm wrong.
Old Mar 7, 2013 | 06:26 AM
jwirth's Avatar
There is an O-ring seal not a gasket
Also hear the same BC847 about the 14mm pump. Have been told driveability is all but gone. Would do a P pump conversion before messing with a ve anymore. More options with ppumps also.
PM Sent 01freeman
Old Mar 12, 2013 | 09:05 PM
Mark Nixon's Avatar
Originally Posted by jwirth
...There is an O-ring seal not a gasket...
Actually, that is also wrong.
The diaphragm actually seals the AFC cover to the housing.
As far as BC847 not knowing his VEs...
Mark.
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
Hmfman91
8
Jul 3, 2015 05:52 PM
davidthomas
Mar 24, 2015 12:41 AM
twm011
Feb 24, 2015 09:11 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
