NV5600 swap
Old Feb 24, 2013 | 01:25 PM
Cow tipper's Avatar
Default NV5600 swap
Just curious as to what I would all need to swap my POS 3 speed 727 for a NV5600? Thanks for any help
Old Feb 25, 2013 | 07:35 AM
Bryson711's Avatar
http://www.turbodieselregister.com/f...-text-included
Sent from my DROID4 using Tapatalk 2
Old Feb 25, 2013 | 11:08 PM
montepig72's Avatar
I would like to ad that in this application the truck being adapted was already a 5 speed Getrag so some of the conversion was already taken care of. One other point I would like to bring up is that the automatic has a 23 spline output shaft, where I think the Getrag is 29 spline. That said the NP205 t-case in your truck wouldn't work. It is pretty cool that there is a 205 that will bolt up to a NV5600 with no adapter though. Awesome write up in that thread, it was very conclusive.
Old Feb 27, 2013 | 07:55 PM
Cow tipper's Avatar
ya i think itd be easier and cheaper to just put an NV4500 in it
Old Mar 3, 2013 | 11:22 AM
CUMMINStagetcha19's Avatar
That extra gear would really help. The guys I know that haul pullin tractors love the 5600. Of the truck pullers I know the 5600 has been stayin together longer than the 4500's. And it's still the bad *** factor of havin a six speed in a first gen.
Old Mar 3, 2013 | 11:31 AM
Cow tipper's Avatar
ya it would be pretty sick to have a 6 speed.
Old Mar 3, 2013 | 07:43 PM
BBD Tech Support's Avatar
Cow Tipper NP205 can be used. You can used your transfer case you have. But you will need to upgrade the input shaft.
Old Mar 5, 2013 | 07:50 AM
Bryson711's Avatar
They also make a 23 spline to 29 spline adapter.
http://www.SHSDiesel.com/site/3a6cbd..._Products.html
Old Mar 10, 2013 | 10:35 PM
That93Guy's Avatar
I did the auto to NV4500 swap, with what I found, it is way cheaper to do the NV4500 but i'd love another gear, I really want a NV5600 with a splitter and have 12 forward and 2 reverse, the more the better right?!? Also, if you have the NP 205 transfercase behind the auto trans, you have a 23 spline output on the trans and a 23 spline input on the t-case. You can't actually upgrade the shaft without upgrading the housing of the t-case because the hole around the shaft bearing isn't big enough but I did the 23-29 spline adapter and it worked out great! I put my NV4500 in about 14 months and 35,000 miles ago and everything has worked flawlessly, my build is here:
https://www.dieselbombers.com/1st-ge...onversion.html
Good luck! Like the other build said, well worth it, but I don't know if I'd want to do another one although it would be much easier the second time around. Its quite a bit of work, and I'd definitely want to do it on a lift, I can't imagine wrestling those heavy trannies in on the ground...
Old Mar 12, 2013 | 08:55 PM
Mark Nixon's Avatar
Contrary to what people would have you believe, you can upgrade the 23 spline NP205 to a 29 spline, you just have to know a good machinist.
Furthermore, the 29 spline input is available NEW for ~$105 and the accompanying 29 spline coupler for ~$30.
For ~$350 in parts and machine work, you can have a cheap 2 spline NP205.
You just have to know the places to get the parts and a machinist.
Mark.
dpgcummins12v
12
Apr 20, 2015 10:24 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
SixSpeed
Jan 11, 2015 01:41 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
