cold start
Old Feb 24, 2013 | 12:13 PM
dieselpig68's Avatar
Default cold start
ok, I checked voltage of both batteries and they are both over 12 volts. checked relay and it is functioning properly, ie over 12volts when turn key on. before I change the glowpugs is there another piece of the puzzle I should check? I understand the harnesses are prone to going bad? I wann check all the easy stuff before i pull the plugs out. Thanks
Old Feb 24, 2013 | 12:54 PM
Twebb833's Avatar
Are you getting white smoke at all?
Old Feb 24, 2013 | 03:04 PM
yes. even when the truck is plugged in it will smoke a little when it starts. can also smell what seems to be unburnt fuel in the exhaust. the last 97 I had did same thing until my buddy discoavered a short in harness(intermtant) that ccontrolled high pressure oil pump. I havent found that to be true with this truck. 128000 miles. maybe time for injectors but fuel milage and power dont seem to be affected once it warms up. I have a hypertech programmer and its programmed to stage three. just installed afe cold air intake cause I blew up the stock one when I put too much starting fluid in. forgot to plug it in and would not start.
Old Feb 24, 2013 | 05:28 PM
Twebb833's Avatar
Have you checked the glowing relay?
Old Feb 24, 2013 | 05:36 PM
yep. glowplug relay is workin fine. 12.67 volts when key is turned to run
Old Feb 24, 2013 | 05:39 PM
Twebb833's Avatar
I know there is a way to test glow plugs, by resistance. However, i have not tried this method.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
jbutler713
Feb 27, 2015 08:44 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 23, 2014 10:44 PM
