Bad Vibrations
Old Feb 24, 2013 | 10:52 AM
sodking's Avatar
Default Bad Vibrations
05 2500 I have a vibration that feels like a bad u joint less noticable at highway speeds. I have checked all u joints every thing is tight, it does go away when throttle is closed. fluids are good in all diffs and transfer case. any ideas where to start to look next?
Old Feb 24, 2013 | 02:05 PM
TheOtherNick's Avatar
Even if they are light they could be rusty and cause a vibration. See if you can see any rust around the grease boots.
Old Feb 25, 2013 | 07:10 AM
CHEMMINS's Avatar
Carrier bearing.
Old Mar 2, 2013 | 08:14 AM
sodking's Avatar
carrier bearing where?
Old Mar 5, 2013 | 09:33 AM
ecurnes8888's Avatar
Gear box stabilizer?
Old Mar 5, 2013 | 11:41 AM
sodking's Avatar
its not in the steering
Old Mar 5, 2013 | 06:23 PM
dcpowell17's Avatar
Mid-Shaft bearing.
Old Mar 6, 2013 | 02:17 PM
CHEMMINS's Avatar
It separates the 2 halves of the rear driveshaft.
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
Mike H
Jan 25, 2015 10:08 AM
12vbomber
Nov 11, 2014 10:58 AM
