Shook me sh*tless
Old Feb 23, 2013 | 01:48 PM
codyawise's Avatar
Default Shook me sh*tless
Well on my way home today on interstate goin 85mph went over a bridge and truck just started shakin pretty bad so I slowed down and kept goin at 65. Decided to see if it would happen again at 85 so got up to it and over another bridge it just shook like hell for a good half mile or however long it took me to stop. Pulled off interstate got out looked here and there couldn't really see nothin out of the ordinary so got on my way home just did 65 rest of way and it was fine but I could still here some noise comin from under truck. Can anyone give me any insight what to look for? Possible driveline issue or suspension issue any help is greatly appreciated
Old Feb 23, 2013 | 01:55 PM
SRTcummins's Avatar
DEATH WOBBLE
Old Feb 23, 2013 | 02:04 PM
codyawise's Avatar
why would it only do it at 85 goin over bumps
Old Feb 23, 2013 | 04:46 PM
Big Bill's Avatar
Track bar and shimmy shock for sure.
Old Feb 23, 2013 | 07:36 PM
tiremann9669's Avatar
Yep DEATH WOBBLE
Check the tie rods and Ball joints while you're at it
Old Feb 23, 2013 | 08:14 PM
JBearSVT's Avatar
Because it upsets the suspension beyond what it's capable of dampening. Once you trigger the imbalance, the only way to get it under control is slow down until it goes away, hopefully before you find yourself careening into the woods at highway speed.
Old Feb 23, 2013 | 08:32 PM
codyawise's Avatar
What do you mean by shimmy shock?
Old Feb 23, 2013 | 10:49 PM
shellinger's Avatar
yep death wobble for sure. still chasing my death wobble down. re balancing my wheels helped mine a lot but still having problems. im assuming they mean the steering stabilizer shock also known as the steering damper when they say shimmy shock. mine is being replaced this week. track bar is a common culprit as well.
Old Feb 24, 2013 | 07:11 PM
codyawise's Avatar
So there is really no for sure issue? Just got to throw money at it and hope it fixes it?
Old Feb 24, 2013 | 07:17 PM
JBearSVT's Avatar
If it only happens at 85mph on bridges, then you don't have it nearly so bad as most. There are a number of inherent flaws in the steering geometry of these trucks, and any one of them could be the main culprit although all or none may contribute. Steering damper is common, the bigger your tires are the beefier it should be to compensate. The track bar is commonly bitched about, and upgrading is commonly praised as the solution. The steering box is mounted to a tin can, and a reinforcement is a well known fix. But depending on the condition of all of your front end components, it's hard to say from here.
