fuel problems
Old Feb 22, 2013 | 10:52 PM
Dodge Ramer's Avatar
Default fuel problems
Hey guys I just put a hot rod vp44 on my truck and I gas on it hard and let off of it in gear and it dies I have to prime it back up like it runs out but keeps 5 psi on the gauge think its air but what do yall think and if it is were
Old Feb 24, 2013 | 02:09 PM
Mopar1973Man's Avatar
Fuel pressure is too low. 14-20 PSI is the suggested range. 10-20 is book values.
Old Feb 24, 2013 | 04:06 PM
H.R.D's Avatar
For starters get rid of those over-sized injector lines and connecting tubes. Then check for fuel leaks.
Old Feb 24, 2013 | 06:52 PM
Y do you say get rid of the lines
Old Feb 24, 2013 | 07:54 PM
H.R.D's Avatar
Because they cause problems like you are talking about and they do nothing for performance, unless you are WAY up there....
Old Feb 24, 2013 | 08:27 PM
Big Line Kit all the way. I've done the math on stock 6mm ID lines and they can only flow a MAX of 75 GPH which is not enough to meet Bosch's 70% return rule. But now flow rate on a 1/2" line is 520 GPH (If I remember right).
You could get a Big Line Kit from Vulcan Performance and then use a better pump like a Raptor or maybe a AirTex if you strapped for cash.
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
