Cummins running rough
Old Feb 21, 2013 | 07:02 PM
Cummins450r's Avatar
Default Cummins running rough
01 cummins 200 horse injectors tst stacked with edge ez air dog. Truck jerks and misses and runs rough under acceleration
Old Feb 21, 2013 | 08:10 PM
H.R.D's Avatar
Do you have a good LP and FP gauge? Sounds like the IP could be going down.
Injector damage can occur with this stack if the pressure levels are to high....
Old Feb 21, 2013 | 08:36 PM
Yeh fuel pressure is good Lp pressure?
Ip?
Old Feb 21, 2013 | 08:40 PM
H.R.D's Avatar
LP= Lift Pump
IP=Injection Pump
What TST do you have and what power level do you run it on? Also how do you have it stacked? The TST should be plugged into the MAP sensor then the EZ plugged into the TST's pigtail and then ez plugged into the stock wiring.
Old Feb 21, 2013 | 08:52 PM
Yeh that's how it's stacked. Tst powermax 3
Ran awesome for awhile like this. I'm aware that it runs too hot but I don't tow and I each the gauges real close
Old Feb 21, 2013 | 08:54 PM
H.R.D's Avatar
From what I have read people who run this stack say to keep the TST on level 2 or below. Any high than that and a lot of pressure is put on the injectors which could lead to failure.
Old Feb 21, 2013 | 08:59 PM
What is the point of the stack then? Mite as well take the edge off and run the tst on 9 way more power than level 2 and edge
Old Feb 22, 2013 | 10:35 AM
H.R.D's Avatar
I am just telling you what I have read man. I don't stack so it doesn't matter to me.
ssmith.77
Nov 25, 2018 06:56 AM
firefighteremt
Feb 2, 2015 01:59 PM
ssmith.77
Jan 11, 2015 02:03 PM
Fishy816
Jan 11, 2015 08:31 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
