95 6.5
Old Feb 21, 2013 | 06:18 PM
kylek's Avatar
Default 95 6.5
ok the truck starts up fine after i bleed it then about 5 to 10 mins at ide it shuts down lift pump is new just got it and its working new ops new fuel pump relay when it dies i have to bleed all over again im the it runs like nothing happend for 5 to 10 mins i dont get it
Old Feb 22, 2013 | 04:11 AM
sureshot's Avatar
air leak if fuel line. sending unit to ip must be checked. u can try and change any spring clamps to a better quality one. top of the sending units are a bad spot for line rot. sending units are 70$ avg, u can then eliminate pluged sock or air leak at top.
this is what fixed my 95 from defueling. good luck
Old Feb 23, 2013 | 01:56 AM
kylek's Avatar
thanks where can i get a sending unit i tryed napa but thay told me 200
Old Feb 23, 2013 | 03:37 AM
Mayhem's Avatar
Is your truck OBD I or OBD II if it is OBD I the easiest way to test the LP is to run a wire from the positive terminal on a battery to the G terminal in the port under the dash, then open the T vavle if you have fuel you can rule out the LP
Old Feb 23, 2013 | 03:03 PM
sureshot's Avatar
napa, norwood ontario is where i got mine. i think they looked up wrong sending unit for you. most expensive 1 i can find for a 95 6.5l is 50$ on the web. i think mine was a Dorman
also my diesel mechanic thought my old one looked fine(no rotted lines)(sock was not plugged) yet it solved my problem 100%. hope you got an ac delco ops as its the only one that can run the lp
Old Feb 25, 2013 | 02:46 AM
kylek's Avatar
thanks man 200 did not sound right
Old Feb 25, 2013 | 09:44 PM
racer55's Avatar
Try running with the fuel cap loose- a plugged vent can cause excess tank vacuum.
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
