95 6:5 antifreeze leak at startet
Old Feb 21, 2013 | 12:11 PM
VIIISecondRide's Avatar
Default 95 6:5 antifreeze leak at startet
Hi I have a 95 K2500 6.5 that I just bought. The PO had starter problems and broke both bolts off. I think he did some drilling now antifreeze is dripping from the bolt hole and the starter was a hanging there! Any fixes for this? Retap and fill the hole with silicone? Block stop leak? Just wanna see how it runs to see if it's worthy of a better fix. Thanks
Old Feb 22, 2013 | 09:11 AM
racer55's Avatar
Shouldn't be any coolant near the starter bolt holes,unless the inner is drilled very deep and even then I think it would hit oil or the opening behind the bell housing first?
Head gasket leak or rotten core/frost plug?
Get a pressure test done.
Old Feb 22, 2013 | 10:32 AM
If I hold my finger over the hole it mostly stops, when I let go backed up coolant comes out. I'm pretty sure the water jacket is close since the freezeplugs are there. I was hoping someone that has seen a bare block would recognise where he could have went wrong, I'm sure this can't be the first one!
Old Feb 22, 2013 | 11:04 AM
racer55's Avatar
Will take a look at the bare block in my driveway later today,might need to drain the coolant and coat the starter bolt with thread sealer like used on head bolts or plumbing:
Thread Sealants : Permatex® High Performance Thread Sealant
http://www.useloctite.com/products/p...ealing4c67.php
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
jorttel
Feb 22, 2015 09:50 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
