Having more problems with my 02 dodge cummins.. wont start
Old Feb 20, 2013 | 08:35 AM
relse11's Avatar
Default Having more problems with my 02 dodge cummins.. wont start
My truck wont start when its cold out by its self but my battiers keep dying on me unless it starts right away (after it gets warmed up). Im wondering if this a battery problem or alternator?...or could it be something else. When i jump it with a another truck it starts right up. Any ideas??
Thanks Randy
Old Feb 20, 2013 | 08:38 AM
jkidd's Avatar
How cold? do you have it plugged in? I would do a load test on your batteries... they are only good for 5-7 years. low temps= less cranking amps. Always replace batteries in sets.
Call if you need assistance
Old Feb 20, 2013 | 02:06 PM
condor74's Avatar
Check the batteries to see if they are holding a charge and pass a load test. Make sure your connections on both batteries are good. After you determine your batteries and wiring are good check your alternator output.
Old Feb 20, 2013 | 07:50 PM
relse11's Avatar
So found out my batteries were bad now need ideas on what kind of batteries to use. I was thinking either optimas or duralast..
Also thanks for the help
Old Feb 20, 2013 | 09:18 PM
condor74's Avatar
If money was not an object I would run 2 Optima Yellow Tops. As far as stock batteries go, I like Interstate.
Old Feb 21, 2013 | 08:25 AM
relse11's Avatar
What is the least amount of cca should i have?
Old Feb 21, 2013 | 09:34 PM
condor74's Avatar
I wouldnt use a pair of batteries with less than 700 CCA each. Not sure on a spec but off the top of my head, that is what I would go with.
Ohiocummins99
Jul 8, 2015 07:30 AM
dlpannebakker
Jun 26, 2015 04:23 PM
PeteBug
Jun 11, 2015 12:16 PM
rschriek
Jan 26, 2015 07:30 AM
elkmaniac
Oct 29, 2014 07:01 PM
