over reving
Old Feb 19, 2013 | 09:29 AM
williehood's Avatar
Default over reving
I have a 1999 5.9 it was losing power the rams would drop to 0 and would lose power changed crank position sensor now when I shift from third to fifth and it over revs I don't think it's transmission speedometer still moving just not linking with rpm just revs
Old Feb 20, 2013 | 12:05 AM
condor74's Avatar
Not sure exactly what you are describing...Can you try and explain it a little different. Not being rude, just want to help.
Old Feb 20, 2013 | 07:07 AM
williehood's Avatar
I just pulled a P1693 code on my Genisys how do you fix that problem I think its the App
Old Feb 20, 2013 | 09:00 AM
condor74's Avatar
P1693 just means there is a code in the ECM. There is a PCM Powertrain Control Module and ECM Engine Control Module. You need to find the code in the other module.
Old Feb 20, 2013 | 11:35 AM
williehood's Avatar
Where is that located and will my genisys work.
Old Feb 20, 2013 | 02:01 PM
condor74's Avatar
I have not used the genisys but the computer is bolted to the side of the engine block behind the fuel filter.
Old Feb 21, 2013 | 02:00 PM
williehood's Avatar
Question if I have to replace my Apps sensor do I have to reset anything or just replace hook up batteries and drive.
question if I have to replace the Apps or throttle position sensor will I need to rest anything or just reconnect batteries and start up.
Last edited by williehood; Feb 21, 2013 at 02:00 PM. Reason: Automerged Doublepost
Old Feb 21, 2013 | 09:36 PM
condor74's Avatar
I am not aware of anything else you have to do. It may do you some good to disconnect and reconnect the batteries but I am not sure if this is needed.
Old Mar 13, 2013 | 03:57 PM
williehood's Avatar
Put new clutch in and is good now thanks for input
