Where is the glow plug controller located at??
Old Feb 18, 2013 | 11:44 PM
JOHNNYBUCK's Avatar
Default Where is the glow plug controller located at??
I have a 1990 F450 7.3 and would like to know where the glow plug controller is located at on this vehicle?? And what would cause my wait to start light to only stay on for 1/2 second??
Old Feb 19, 2013 | 06:04 AM
autostroker's Avatar
I believe the glow plug controller on that engine is in the center of the valley on the back of the engine. round thing sticking up with a big plug on the top of it. about where the distributor would be located on a small block chevy. And yes, a bad controller would cause the wait to start light to go off early, if it isnt letting the glow plugs cycle right.
Old Feb 19, 2013 | 08:38 AM
JOHNNYBUCK's Avatar
Thanks for the info. I'll let you know if this fix's & solves my problem.
Old Feb 19, 2013 | 12:44 PM
perkinsd_theone's Avatar
Mine is a 92 F350 7.3 and the controller is located just above the valve cover on the left bank if looking from head on.
Old Feb 21, 2013 | 04:52 PM
7.3 idi 1990's Avatar
I wired mine over to manual system and it works great
Old Feb 22, 2013 | 10:03 PM
DevilDog6154's Avatar
im having the same problem, with my 90 f350. if you figure it out let us know.
Old Feb 27, 2013 | 12:24 AM
92fourdoorbronco's Avatar
I own a 92 four door bronco that I had problem with the glows when I bought it after buying controller,glows,solenoid, I found out the main plugin had some melted wires so I fix them and the wiring was the original problem that I had with my
Old Feb 27, 2013 | 09:15 AM
JOHNNYBUCK's Avatar
Well I finally got it fixed. I wired it over to a manual push button and works great now. Thanks for all the helpful replies.
Metz1234
Mar 3, 2016 10:20 PM
1997silverado
Mar 12, 2015 11:11 PM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
