need nv4500 or nv3500 2wd transmission complete
Old Feb 17, 2013 | 07:12 PM
deck60's Avatar
Default need nv4500 or nv3500 2wd transmission complete
I need a 2wd transmission a nv3500 or a nv4500 I am doing cummins 4b either a 3.9 or 3.3 in a dakota
text 6056956211
I am looking for a cummins engine for my conversion a 4 cylinder looking for fuel mileage
so I figure a 3.3 4.5 or 3.9 if you have one text me
Old Feb 26, 2013 | 12:22 AM
Mark Nixon's Avatar
A good candidate tranny for the conversion would be an AX15.
What's more, Advance Adapter makes a set-up that bolts to the AX15, which will adapt to the Ford Small block bell housing.
The Ford Small block adapter set-up behind the 4bt is a fairly common set-up.
When I get around to doing the twin turbo 4bt in my 1996 Dakota, this is the set-up I will run.
Mark.
W350-4x4
Nov 12, 2014 09:35 AM
