swap a 01 to 99
Old Feb 16, 2013 | 08:37 PM
hip66's Avatar
Default swap a 01 to 99
I cracked the block in my 01 2nd gen swapped in out to a 99 2nd gen.Used the 99 wiring harness & the 01 ECM(all I had).01 did not have a crank sensor the 99 does.The motor will start & run after a min or so it idels high and the rpm gauge quits and I get a PO341 code but stays running(can't drive yet).Someone told me I might have to change the camgear to read the cam position sensor.Are the gears different? Can I try anything else frist? HELP!
STDiesel59
Jul 11, 2015 10:09 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
F250MACH
Apr 26, 2015 05:19 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
