throttle problem
Old Feb 15, 2013 | 10:49 PM
williehood's Avatar
Default throttle problem
just replaced crank position sensor now when I step on gas rpm goes up and speedometer slowly moves up mainly when I shift in forth and fifth gear going up hill power is there speedometer doesn't move even if on gas. 1999 dodge 3500 duaille 5.9. any clues.
sorry guys I replaced crank position sensor.
Last edited by williehood; Feb 15, 2013 at 10:49 PM. Reason: Automerged Doublepost
Old Feb 15, 2013 | 10:59 PM
H.R.D's Avatar
So the speedometer is not working correctly? Probably be the VSS (Vehicle Speed Sensor). IIRC it is on the rear axle on top on the passenger side.
Old Feb 16, 2013 | 07:46 AM
williehood's Avatar
The speedometer works second and third gear everything is insink but forth and fifth gear it overreves
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
kraftsman
Ford Powerstroke 08-10 6.4L
Mar 4, 2015 02:00 PM
1stgenswap
Nov 3, 2014 09:45 PM
signoremint
13
Oct 21, 2014 07:21 PM
