Fresh 48RE no go
Old Feb 14, 2013 | 08:29 PM
dcpowell17's Avatar
Default Fresh 48RE no go
I did a seal to seal rebuild on my 2007 48RE plus a Transgo VB kit. GM pressure solinoid. All air checks were good. Accumulator pressure is 40 min and 100 max. Should be 60 / 200. Reverse port is good at 280. Front servo won't build over 60 in 2nd and 3rd. I have gone through both the tranny and VB looking for any issues. BTW. I did not go through the OD section. Any ideas?
David
2007 Maga Cab. Compound turbos 700 hp 1200 ft lb torque.
Old Feb 14, 2013 | 09:49 PM
dangerous1965's Avatar
Valve body issue! you may have a bad leak or a pump problem. Give Goerend a call they are great on the phone! I would rebuild the overdrive if your clutches get worn down you will blow the seal out! Did you adjust the pressure?
Old Feb 15, 2013 | 08:09 PM
dcpowell17's Avatar
Blew the rear drum inner lip seal and smoked the brand new red eagles and kolen steels. Never made it out of the drive way. I pulled the tranny out today in 14 min and 37 seconds.
Old Feb 19, 2013 | 05:35 PM
dcpowell17's Avatar
Default Still no go
Replaced the rear drum clutches and all lip seals. Accumulator pressure was good while on the jack stands. Reverse strong. Started out in 1st. Did not shift. Then no go. Rechecked accumulator pressure. 20/100. WTH!
Got in my rig and started it up. Had accumulator pressure @ 70psi. Which is what it should be with the VB kit. Started out in 1st. Did not shift. Reverse back into the driveway and 25lbs of pressure. What the hell is going on?!?
Pulled the VB back off. I found the throttle valve had the wrong spring. The kit said use their green spring. wrong spring. installed a sonnax throttle kit. Started it up. 65lbs in drive @ idle. good firm shift into first then no shift, a little more throttle no shift. left off and coast. tranny cold @ 140. Now low line pressure. 25lbs. should be 90 to 110 lbs. Why do I loose the line pressure?
Transmission Line Pressure BD Pressure Transmission in DRIVE w/Engine at idle 90-110psi
Transmission in DRIVE w/Convertor Locked up @ WOT 170-200psi
This is what my pressures should be. Obviously I misread them.
Last edited by dcpowell17; Feb 19, 2013 at 05:35 PM. Reason: Automerged Doublepost
Old Feb 21, 2013 | 07:44 AM
dcpowell17's Avatar
Default update
Pulled tranny.......again. Installed a new pump.....Same issue.
Ordered a valve body. Better fix it or I made need a place to stay when my wife boots me out.
Old Feb 21, 2013 | 08:20 AM
If you would have talked to Goerend first this never would have happened! That's ok lesson learned! i wonder if it's something simple like a :47RE 48RE Billet Accumulator Piston Sonnax 47RH 46RE 46RH A727 A904 Transmission | eBay If so don't send in your VB as a core! I have one you can use!
Old Feb 21, 2013 | 06:29 PM
dcpowell17's Avatar
People you don't buy from aren't usually very good to work with. My buddy owns High Tech Transmission he gives good advise. At 1200 ft of torque I've been through this tranny 4 times and never had a problem. I know this tranny like the back of my hand. That is what makes it so frustrating. I tried to buy a VB from Jeff Garman but I guess he has enough customers. The VB must be sucking air. BD valve body is on the way.
I do run a Sun Coast billet accumulator.
Old Feb 28, 2013 | 08:24 PM
dcpowell17's Avatar
Default Found the problem!!
I left the damn sealing ring off the rear splined hub. Holy crap! I missed it 4 times. What a dumb a$$.
Old Mar 5, 2013 | 06:16 PM
dcpowell17's Avatar
Default Fixed it!
FIXED IT!
Old Mar 5, 2013 | 09:09 PM
TheOtherNick's Avatar
At least it was simple once you found it.
Kfohne21
10
May 12, 2022 10:13 AM
jeremiah1
Jul 21, 2015 06:35 PM
Hmfman91
8
Jul 3, 2015 05:52 PM
Jgloveracob
Wanted To Buy (WTB) - Used
Apr 18, 2015 04:19 AM
