89 dakota gas to diesel swap info needed
Old Feb 14, 2013 | 02:17 PM
Navajo's Avatar
Question 89 dakota gas to diesel swap info needed
Im wantn to swap my 89 dakota 3.9 6cyl. 4speed auto to diesel. But i dont know what size to get nor the transmission and conponents to do it. Please help mee
Ps. I also dont know where to get the engine and tranny
Old Feb 14, 2013 | 04:50 PM
Cow tipper's Avatar
find an old bread truck on craigslist with the 4bt cummins in it and take out everything you will need for the swap
Old Feb 14, 2013 | 04:55 PM
Navajo's Avatar
Will the mounts from the 3.9 line up or will i need new mounts
Old Feb 18, 2013 | 04:45 AM
montepig72's Avatar
I highly doubt anything will bolt up in your Dakota. I think you will need to use the engine crossmember from the donor truck that you end up buying, plan on extensive fabricating as I am sure your frame rails are much narrower. Also consider the enormous weight difference of even a 4bt, let alone a 6bt. You will need to figure out how you plan to deal with that. I would suggest a solid axle front swap if you intend it to be 4 wheel drive. This sounds like a killer project, I hope to see some pics!
Old Feb 18, 2013 | 10:11 AM
peckens's Avatar
i would look at 4btswaps forum. they have alot of good info there
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
tilopa
Aug 21, 2015 03:19 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Oct 31, 2014 06:10 PM
