Wanting to buy fuel pump
Old Feb 13, 2013 | 05:14 PM
99coalroller24V's Avatar
Default Wanting to buy fuel pump
Im not sure if this is where we ask, but im looking to buy a aftermarket fuel pump that will support a drag with 100 hp injector nozzles?
Old Feb 13, 2013 | 06:11 PM
diesel life's Avatar
I assume your talking about a drag comp??? if you fill your sig out it well help the people trying to help you that away they can see whats all done to your ride... assuming you were talking about a drag comp and 100hp injector nozzles i would either put in a a airdog 150 or a fass 150, i run the airdog and like it so far.. do you have guages on your truck?? if not i would get them and the fuel system before putting the 100hp nozzles in, the vp44 does not like to be starverd for fuel it will toast your pump
Old Feb 14, 2013 | 08:17 PM
how you fill your sig out out here???
Old Feb 14, 2013 | 08:19 PM
H.R.D's Avatar
Click on "User CP" in the toolbar below the Diesel Bombers banner, then go to the option: edit signature.
Old Feb 14, 2013 | 08:40 PM
i believe its up and going. I never crank the drag comp up due to the starving VP44 but i have performance parts and all sitting there basically and cant even use them
the raptor FRRP pump wouldve done me good with my mild setup but i have been hearing bad things about pureflow on another cummins forum page and im not messing with it. Fass ive heard good but its electrical and ive been hearing a lot of fellas speaking of the DTT Assassin mechanical lift pump which is what im looking for unless i found a good deal on a electric powered pump
Last edited by 99coalroller24V; Feb 14, 2013 at 08:40 PM. Reason: Automerged Doublepost
Old Feb 14, 2013 | 09:22 PM
sounds like you have it all planned then... i know all about having the parts sitting around waiting i have a built tranny waiting to go in i walk past everyday in the garage just need the time to put it in.. until that the juice stays on level 3 and it still kicks the power down occasionally
Old Feb 14, 2013 | 09:27 PM
yea buddy, i got a set of DDP 100 hp tips for $85 dollars which is one of them rare deals once i finish my next 3 years of college cause im a freshman right now, then ill be able to have money to do more crap to my truck
Old Feb 14, 2013 | 09:36 PM
that is a good deal are they used or new
Old Feb 16, 2013 | 07:03 PM
Used but the guy said they only had 2,000 miles on them
Old Feb 18, 2013 | 04:12 PM
there basically new then.. good luck let us know how they work for ya
