Side cover leak...
Old Feb 12, 2013 | 06:27 PM
brand97's Avatar
Default Side cover leak...
I have a 99 cummins and originally thought I had the common vac pump leak but now I see it is the side cover on the motor driverside, has anyone replaced one of these, or had it done?? How much was it or how long did it take??? Thanks again
Old Feb 12, 2013 | 06:50 PM
rees1060's Avatar
If you look a few post down from yours there was a discussion about the same thing
Old Feb 12, 2013 | 08:24 PM
BarryB's Avatar
I've replaced mine. It was the first time I ever ripped into a diesel. Took my time and did my research. it wasn't that bad, especially if your good with the wrenches. You need to remove the Injection pump to get to all the bolts. basically remove everything on the side of the motor. If i remember correctly, gasket was cheap, 15 bucks maybe.
Old Feb 13, 2013 | 10:38 AM
brand97's Avatar
Do you remember about what kinda time you had into it?? a few hours a day? ish??
Old Feb 13, 2013 | 06:28 PM
BarryB's Avatar
I did it when I had some time off, I think I might have had 4 hours in it off and on. But I had more time on the net researching youtube videos and such. Like I said earlier. I did my research before tackling this fix.
Old Feb 20, 2013 | 12:01 PM
brand97's Avatar
K so I started on my side cover gasket repair and made it to the injector pump and wimped out!! not sure enough of myself to tear that far into my daily driver and have heard that bleeding out the fuel system can be a nightmare?? Looks like the pump the seperator and the fuel lines all have to come out of the way??I will try to get more info on that first i suppose
Old Feb 20, 2013 | 02:30 PM
condor74's Avatar
Removing the injection pump is not that bad. The transfer lines come out in 2 groups of 3. I have not done the side cover but I have changed several injection pumps. Once you do a few of them, It takes about an hour from removing to complete.
Here is how I do it.
1 remove the road draft tube filter on the front of the timing cover.
2 remove the nut and washer on the front of the injection pump.
3 use a fan wrench to rotate the engine so that the key way on the pump shaft is strait up and down
4 remove the oil dip stick and intake
5 remove the banjo bolts that hold the fuel supply and return lines
6 loosen and remove the line nuts on the back of the injection pump.
7 loosen and remove the lines where they go into the cylinder head.
8 remove the hold down bolts on the top of the intake.
9 remove all the fuel lines
10 use a 15 mm socket and extension to remove the 4 bolts that hold the injection pump to the back of the timing cover
11 use a 13 mm socket and remove the bolts on the bracket at the bottom rear of the injection pump.
To reinstall just reverse the steps.
To purge the air loosen the 3 injector lines at the head that you can easily reach. Turn the key on and have someone crank it until you see fuel coming out of the fuel lines. it will sputter to life and you can tighten them up while it is running. It will run smoother as you tighten each line up.
Old Feb 20, 2013 | 05:03 PM
BarryB's Avatar
Don't let it the best of ya.
Old Feb 26, 2013 | 07:56 PM
brand97's Avatar
Thanks for the info I have started this project oday but ran out of time, got to the point where I had to have the puller to pull the injector gear off. Hope she goes back together in the morning good!! again thanks
Old Feb 26, 2013 | 09:04 PM
BarryB's Avatar
A cheap steering wheel puller will work for "pushing" the pump out of the gear. I bought the actual puller for it after I did mine. So i have it for the next time. Just make sure the key way is up. You can ping the key just a bit with a center punch to get it to stay in place. good luck with the project.
