General 48re question
Old Feb 12, 2013 | 09:57 AM
lholiday's Avatar
Default General 48re question
I apologize if this is the wrong forum.
2003 ram 2500 5.9 48re bully. When accelerating while in overdrive, is it normal for the torque converter lock to disengage? How would you prevent that and make it stay locked?
Thanks,
lholiday
Old Feb 15, 2013 | 08:06 PM
dcpowell17's Avatar
You need to check the governor solenoid and pressure switch. They are notorious for blowing out.
Old Feb 18, 2013 | 02:19 AM
Blue04cummins's Avatar
I had the same problem. Any kind of programmer, chip, turbo, etc. will push the stock torque converter and make it slip. If it bothers you that bad, then the way I got mine to stop on my 04 was I wired a torque converter lockup switch, which helped a lot and actually saves your tranny if used correctly! If you need any help or pics of how I did it i'd be more than happy to give you a walk through.
Kfohne21
10
May 12, 2022 10:13 AM
Joracing3
Sep 10, 2016 05:28 PM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
