fp gauge question
Old Feb 12, 2013 | 12:33 AM
sampewsey's Avatar
Default fp gauge question
I have a ev2 gauge for my 01 2500
I have searched and am still confused on if i need a banjo bolt, a snubber or both?
Thanks
Sam
12MM Banjo Snubber - '98.5-'09 Dodge Turbo Diesel-Geno's Garage
would this be the correct part?
Old Feb 12, 2013 | 05:45 PM
rees1060's Avatar
Depends on where your putting the sender, if you locate it right at the vp yes you will need a 12 mm banjo snubber.. Some guys use the banjo bolt with a grease hose to get the sender away from the vibration of the pump, I had a grease line swell shut and cut off all fuel on one of my trucks so I don't use that setup(just my preference).. I did away with all banjo bolts on mine with 3/8 line all the way from the tank used a 3/8 tee with 1/8 npt and connected between the stock filter and the vp
Old Feb 12, 2013 | 07:32 PM
sampewsey's Avatar
great thanks ordered parts today!
Old Feb 12, 2013 | 07:44 PM
rees1060's Avatar
You bet.. Good luck!
TurboBoy6.5
Apr 12, 2015 11:22 PM
MrCat4974
Mar 23, 2015 11:30 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
scottxmorris
Oct 8, 2014 02:14 PM
