needs some info on turbo's
Old Feb 11, 2013 | 11:50 AM
cumminsfreak5.9's Avatar
Default needs some info on turbo's
i got a 91 first gen daully 4x4 5 speed N/I, i got ddp injectors,air dog 150, bully dog fuel pin and 3200 bosch gov. spring, and the STOCK h1c turbo and ive done went threw 4 of them and im looking to upgrade anybody have any thoughts on what to go with on a low budget (hx35,he351)etc.?
Old Feb 11, 2013 | 12:33 PM
H.R.D's Avatar
IMO the ones you have listed are good options and I would go with an HE351CW myself.
Old Feb 11, 2013 | 01:06 PM
i was looking at the he351cw but what is the electronic hookup on the front of the turbo for? do i bypass that or just leave it alone?
also what are anybodys thoughts on the ebay turbo's?
Last edited by cumminsfreak5.9; Feb 11, 2013 at 01:06 PM. Reason: Automerged Doublepost
Old Feb 11, 2013 | 02:00 PM
H.R.D's Avatar
Don't buy a turbo off ebay unless you can verify it is a genuine Holset.
You can put a mechanical wastegate instead of an electronically controlled wastegate on the CW.
Old Feb 12, 2013 | 12:26 AM
Mark Nixon's Avatar
The sensor on the compressor housing of an HE351cw is a boost sensor, as used on the 2004.5 through 2007 5.9 trucks.
You can leave it as is, or remove it and plug the hole.
The HE351cw uses a pressure-activated waste gate, so there are no electronics to make it function.
Mark.
Old Feb 12, 2013 | 12:03 PM
H.R.D's Avatar
Mark.
Boy I fell like a jackhead, had a moment...
Thanks for the clarification.
After some research I have found this that might help you out cumminsfreak:
File Type: pdf
Old Feb 12, 2013 | 04:33 PM
jkidd's Avatar
HE351CW is ideal for the low rpm fueling curve of the VE pump. We have hx40 and he351 downpipes for the 1st gen.
Depending on what injectors you have you may need to step up to a s300 turbo with upgraded internals.. the he351 should be support about the same HP and a super B turbo
Aug 7, 2015 12:40 AM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
Dec 3, 2014 08:10 AM
760DAN
Oct 31, 2014 12:53 PM
offroad00
24
Oct 23, 2014 03:28 PM
