is this true hp or just numbers
Old Feb 11, 2013 | 08:22 AM
dpoole's Avatar
Default is this true hp or just numbers
I have an 06 3/4 ton 6 speed standard my mods are banks air ram w/ scoop and banks automind which is supposed to add 100 hp and the air ram adds about 25 hp so does that put me at 450 hp or is it just numbers?
Old Feb 11, 2013 | 09:05 AM
dangerous1965's Avatar
Just numbers! Other things go into the equation like fuel pressure! Banks is pretty good at not over stating their products. A dyno would give the right answer but somewhere near 400 is possible!
Old Feb 11, 2013 | 02:18 PM
dpoole's Avatar
So how much hp can you get with stock injecters or should i just start with exhaust, air flow , like intake and intercooler?
Old Feb 11, 2013 | 03:38 PM
I've seen 500hp+ with stock injectors
Luke
Old Feb 11, 2013 | 05:28 PM
dpoole's Avatar
What all mods was done?
Old Feb 12, 2013 | 08:07 AM
Intake, exhaust, CP3, Programmer! If you have the factory 4" exhaust leave it alone plenty of flow!
Old Feb 12, 2013 | 01:54 PM
jkidd's Avatar
remember you do not start with 325hp at the wheels, it is 325hp at the crank, once you consider dirvetrain losses you are about 15-20% lower
Old Feb 12, 2013 | 05:43 PM
dpoole's Avatar
So the cp3 makes a big difference I'm new to diesels
joejack6.0
Oct 25, 2014 05:41 PM
dougcarlo
Oct 18, 2014 03:15 AM
