94 idi wont stay running down the road
Old Feb 10, 2013 | 06:59 PM
jaredkeller96's Avatar
Default 94 idi wont stay running down the road
i have a 1994 f250 idi turbo, and it will sit and idle all day long but i go to drive it and itll shut off, fuel filter light comes on and shuts down, we put a new fuel filter in it, new lift pump, injector o-rings, and lines, it still wont run down the road, od light comes on also
HELP please,
Old Feb 13, 2013 | 06:37 PM
fordidipower's Avatar
Do you have a water fuel separator? I'm not really familiar with 7.3 but if a 6.9 has water in the fuel your in a world of hurt
Old Feb 20, 2013 | 11:20 AM
perkinsd_theone's Avatar
I have a 92 7.3 and currently experiencing the same symptoms. Here's where I am with it..
changed fuel filter.... no luck
changed mech lift pump ... no luck
checked fuel psi... about 4 to 5 psi....
changed return lines on injectors as well as O rings..... no luck
currently dropping the tank, draining, inspecting... and breaking down the fuel lines supply and return, and blowing them out with 90 PSI.. I'm breaking the lines down at each junction individually hoping to find some "culprit" of some kind.
I'll keep ya posted once I get her back together. That should be today with some luck.
Old Feb 21, 2013 | 03:01 PM
BigT1's Avatar
Does it die right when you put it into gear or after you have traveled awhile? does it spit and sputter or just shut off all the sudden?
Old Feb 25, 2013 | 09:25 AM
ok...... success for me.
see above post of mine...
but this worked for me.
I dropped both tanks... cleaned them... took supply and return lines apart at each junction and blew them clean with 100 psi.
put everything back together and have driven truck 2 days now with no issues.
everything was easy work.. just time consuming.
wildhorsemfg
Show And Tell
Sep 20, 2015 11:26 AM
Blanton
Apr 15, 2015 06:29 PM
carid
Diesel Bombers Sponsors
Jan 12, 2015 04:32 AM
Noshawn
Dec 24, 2014 09:30 PM
larry frazier
Nov 16, 2014 12:13 PM
