2000 chevy 6.5 not starting
Old Feb 9, 2013 | 05:36 PM
Diesel86's Avatar
Default 2000 chevy 6.5 not starting
Having a starting problem with a 2000 chevy 6.5 diesel. Cranks fine, have fuel supply to injection pump, transfer pump, injection pump, PMD, and oil pressure switch were all just replaced today still no fuel at the nozzles. Checked battery connections there ok ground on back of the intake seem to be ok. Any suggestions ? Have not checked power tomecm or pmd, really not sure what pins to check.
Old Feb 10, 2013 | 11:03 AM
racer55's Avatar
fuel sol fuse or ECM B fuse?
Old Feb 10, 2013 | 08:23 PM
Diesel86's Avatar
Bothe are good. Pmd has good power and ground. Check signal rom the ECM while cranking, I got zero then 2.2 volts for a split second then back to zero. Still no running. Isn't it sopose to be around 1.2 volts constant?
Old Feb 10, 2013 | 08:26 PM
racer55's Avatar
Ditto what I posted here for ya:
2000 chevy 6.5 won't start - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Excursion73
Oct 27, 2015 05:21 PM
Chevy6.5/2500hd
Jun 21, 2015 02:37 AM
Chevy6.5/2500hd
Jun 1, 2015 09:44 AM
Snoobly
Dec 11, 2014 11:59 AM
cde345678
Nov 15, 2014 05:28 AM
