2005 6.0 when in gear with foot on brake engine miss
Old Feb 9, 2013 | 04:54 PM
mcshoeing's Avatar
Default 2005 6.0 when in gear with foot on brake engine miss
Just bought 2005 6.0 3wks ago. Ran fine. 2wks ago wife told me when she steps on the brake, it misses a few times. I can hear a hissing noise (like a vaccuum leak), but when stepping on brake it stops, but will miss a few times. Backing down a steep driveway while riding the brake it really misses.
Old Feb 9, 2013 | 08:09 PM
bobfbigman's Avatar
Does it miss, or does it have a choppy/loapy Idle? I would pull the connector off the ICP sensor on the pass side valve cover and run it to see if it still does this, if it takes care of the problem then a new ICP sensor will fix your problem
Old Feb 9, 2013 | 09:05 PM
mcshoeing's Avatar
Thanks for the reply. It doesn't loap. When backing down a steep driveway and riding the brake, it will miss until I stop/put in drive and go forward. Then it runs fine. When you stop at a light/stop sign, it will miss a couple times then smooth out.
Mainly does it when brake is applied
Old Feb 9, 2013 | 09:31 PM
bobfbigman's Avatar
Test the FICM, there is a test procedure at top of the 6.0 page, could be that. If it does it only when cold it could be stiction, if it does it when hot too it could also be an injector going bad. It would really help to put it on a scanner to read if any codes have been thrown, if it is an injector then it ought to throw a code for that injector, if it throws a code for a bunch of injectors then it is most likely a failing FICM, which can be repaired for alot less then a new one.
Old Feb 9, 2013 | 10:21 PM
mcshoeing's Avatar
Ok. I will try the ICP Sensor tomorrow and see if it does anything.
burndiesel
10
Feb 7, 2023 01:15 AM
Cavnar
Sep 9, 2015 07:18 PM
Cavnar
6.0L Performance
Apr 7, 2015 10:35 PM
smbenoit_79
Feb 2, 2015 01:35 PM
alex74708
Dec 28, 2014 04:18 PM
