Extremely low fuel pressure... im stumped..
Old Feb 6, 2013 | 12:40 PM
dieseltech2525's Avatar
Default Extremely low fuel pressure... im stumped..
I was driving from the gas station the other day about 5 miles from my house and the gauge was showing 18 psi fuel pressure. i look down 1 min later and its reading 2 psi!! im like holy ****.. i almost wreck trying to get off the road. i shut her down. get out the truck. nothing... so i drive her home on about 5-6 psi when i get home shes limping on 2 psi into the driveway. today i installed an inline filter, and changed the stock fuel filter.. my truck is idling at 17 psi stable... then i take it down the road and it drops down to 2 psi? im thinking lift pump? At startup when im sitting im my driveway doing nothing it idles at 17 psi but when i drive it and come back the fuel pressure wont rise above 5-6 psi.
Old Feb 6, 2013 | 12:41 PM
GuyWithA24Valve's Avatar
Do you still have the stock lift pump or do you have an aftermarket set up?
Sent from my iPhone in the cab of a Caterpillar
Old Feb 6, 2013 | 12:43 PM
Farmboy 2.0's Avatar
What gauge is checking it? Manual, Electric, or like adrenaline or juice monitor? I would reference with a different gauge if you can. if not id say the Lift Pump is dieing. Is it a stocker or a aftermarket?
Old Feb 6, 2013 | 12:47 PM
im almost positive its stock... the gauge is a 30 psi glow shift...
Old Feb 6, 2013 | 12:49 PM
Try a manual gauge from napa for comparison. The glow shifts have a horrible track record of being unreliable. it may just be a sensor
Old Feb 6, 2013 | 01:08 PM
i just called around and no auto parts stores around here have a fuel pressure gauge
Old Feb 6, 2013 | 01:09 PM
Can they order one in for you?
Old Feb 6, 2013 | 01:11 PM
no they said they dont carry them... im trying to fix this cuz i work tommorow and i have no other vehicle to drive
Old Feb 6, 2013 | 01:28 PM
hmmm
Old Feb 6, 2013 | 01:29 PM
im thinking i should just get an fuel pressure tester and test the port on the injection pump to see if it has enough pressure
