need advice asap
Old Feb 6, 2013 | 11:29 AM
lauber_03's Avatar
Default need advice asap
Moving back to illinois from mississippi lost tc lockup, all gauges working fine. Fluid level good and temp is in 140's. Shifts fine too, checked grounds and other wiring to pcm. Doesnt attempt to lock in 3rd or 4th!!@
Old Feb 6, 2013 | 03:36 PM
Nutty Jeeps's Avatar
how many miles are on your trans?
Happened to me and I needed a new tranny
Old Feb 6, 2013 | 03:45 PM
lauber_03's Avatar
About 1500
Old Feb 6, 2013 | 04:10 PM
we'll then I would hope that's not the problem..... Did the place that installed it give you any warranty at all? Or did you install it yourself?
Old Feb 6, 2013 | 04:17 PM
Bryce's Avatar
Check the trans fuse and try swaping the trans relay with the horn relay. I kinda doubt that will work. I'm guessing its more than likely the t/c clutch solenoid but I'm no trans pro. Hope you get it going.
Old Feb 6, 2013 | 09:07 PM
lauber_03's Avatar
ya i tried the fuse and relay, nothing. i was rolling 22mpg with my trailer, after i lost lock up i went down to 16......kinda sucks doing 60mph
GT_Eleanor
Aug 25, 2015 09:35 AM
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
Mikeyfz45083
Transfer Sled Pulling
Nov 14, 2014 11:04 AM
