Burnout mods?
Old Feb 5, 2013 | 08:42 PM
codyawise's Avatar
Default Burnout mods?
Gettin married here in may and figured what better way to celebrate then roasting some tires. Issue is I can't get a good one down if I do it's only like ten feet all Rollin. I want to be able to sit still and spin em. Truck is a dually. Currently have smarty, afe air box, 4 in tb strait pipe and pusher manifold. Waitin on my adjustable boost elbow to show up and git it put in. Any help as of to how to get some white smoke rollin, what other fairly cheap mods? What's best settings on smarty to help me get em spinning?
Any help is great
Old Feb 5, 2013 | 09:36 PM
KillStroker's Avatar
well off the top of my head the cheapest might get you a little further is air them puppys up i know you can squeeze 80 psi into see what you can get in there you will be up on the centers and once there hot they will spin
Also those are big brakes in the rear.... IF your really wanting to do on big *** burn out but not gonna drive far afterwords....Line Locks are cheap and if you want it that bad disconnect your rear brake lines and cap them off. Allot of work tho for a burnout.
Old Feb 6, 2013 | 09:23 AM
codyawise's Avatar
What you mean line locks? Where do I get and where do they go
Old Feb 6, 2013 | 10:06 AM
GuyWithA24Valve's Avatar
A line lock engages your front brakes only. That's what most drag racers use for the burn out box. You can get them online at Jegs or Summit Racing
Sent from my iPhone in the cab of a Caterpillar
Old Feb 6, 2013 | 10:38 AM
codyawise's Avatar
Where's it hook up and how do you engage and disengage
Old Feb 6, 2013 | 12:11 PM
Farmboy 2.0's Avatar
Bleach the tires
2004LB7
29
Feb 29, 2016 06:00 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
lb7Garrett
Chevy/GMC Duramax 01-04 LB7
Feb 15, 2015 09:02 PM
dieselpowa
Jan 26, 2015 03:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
