lift pump location
Old Feb 5, 2013 | 07:34 PM
countycoalroller's Avatar
Default lift pump location
ordering a new lift pump next week on payday and cant figure ot where my lift pump was originally located. here is a pic of what it looks like bu it is frame mounted but im pretty sure its a block mounted pump thats been relocated. also the wires to the plug on the pump have been cut and only one wire is hooked up both under the hood and at the pump itself. there is some random length of rubber fuel hose also where the hard lines hook into the pump. any info would greatly be appreciated!!
Old Feb 5, 2013 | 11:30 PM
Bryce's Avatar
Your picture isn't showing up so all I can't help you with wiring details but here is a pic to show where the factory pump location is.
Old Feb 6, 2013 | 08:15 PM
ok im tryin to post it again. its appears to be a block mounted pump thats been relocated like a fass with a relocation kit to put it on the frame. im positiv its the stock pump.
i was looking around and i saw the bd diesel lift pump kit and mine looks exactly the same. the wiring it comes with looks just exactly how my lp is wired right now. and even with the edge on 5 and 75 hp sticks im still able to pull 8-9 fuel psi at WOT?? at idle itll do 16-18. but itll sometimes dip down and idle at 12?? reaspon why i thought it was a factory lift pump.
Last edited by countycoalroller; Feb 6, 2013 at 08:15 PM. Reason: Automerged Doublepost
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
