2005 6.0 cold crank no start
Old Feb 5, 2013 | 05:54 PM
hcorbett's Avatar
Default 2005 6.0 cold crank no start
Hello guys I need some help I have a 2005 f350 cold it cranks and hits but only for a second ,no white smoke ,when hit I see a little brown or black smoke ,ficm checks at 48.5 volts cranking.
Old Feb 6, 2013 | 03:18 AM
97cummins's Avatar
Old Feb 11, 2013 | 06:38 PM
H.R.D's Avatar
Moved this thread for you to the correct section to help get more exposure.
Old Feb 11, 2013 | 06:53 PM
mysterync's Avatar
Do you have the ability to see live data? Do you have fuel at the filter housing?
Do you have the ability to check lube oil pressure?
Old Feb 19, 2013 | 06:06 PM
Earl L Little Jr's Avatar
Default 2006 Ford F350 No Start
Have the same issue. The EGR cooler hose was leaking so we pulled turbo installed new hose and reassembled everything, then had hard start took forever and ran rough. Took Turbo back off cleaned it and re installed, Now no start at all.
FICM test good. 48 Volts.
Just weird was running fine just leaking antifreeze. Now we are stuck and no Idea what to do.
(previously checked STC fitting already updated, and so are the down tubes)
HELP
CJ Morin
19
Nov 20, 2018 07:30 PM
Cavnar
Sep 9, 2015 07:18 PM
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
dandbmcc
Mar 14, 2015 11:05 PM
