95 6.5
Old Feb 5, 2013 | 09:42 AM
kylek's Avatar
Default 95 6.5
runs good to it gets warm it dies out just setting there its driving me nuts done put a new fuel pump relay on it new ops i can hear the lift pump but sometimes i cant and and if i hold lift pump in my hand it gets hot so i think its the lift pump how do i do a test?? to make shore the its the lift pump i tryed the one i found online open the
t-valve y the truck is runing and when i did that my truck died i just wanna make shore thats my problem b4 i go buying more stuff i dont need thanks
Old Feb 5, 2013 | 06:56 PM
racer55's Avatar
If the truck dies when the Tee valve is opened- the LP is not providing enough fuel.
That could be because of several reasons:
A bad lift pump-AC Delco from a 93 is the best stock replacement LP-FASS or Air Dog are good expensive aftermarket options.
A bad LP ground can also cause excess current draw from the LP.
A plugged vent in the filler cap causing more vacuum in the tank than the LP can overcome.
A plugged sending unit sock preventing enough fuel flow.
A bad OPS not powering the LP-AC Delco ONLY for OPS replacement and google "OPS relay mod" and build it or buy a kit from Kennedy Diesel.
Another problem could be a plugged fuel filter or last ditch screen that is located in the fuel manager on the fuel heater mast.
Old Feb 6, 2013 | 02:24 AM
kylek's Avatar
i just put a ac delco ops on it and did the mod i think its the lift pump ill let you know if the lift pump helps thanks for ur help
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
